MF 135 PTO disengaging
   / MF 135 PTO disengaging #1
Buckie02
Alexandria TN
1965 Massey 135 Gas
Just bought tractor. 1965 MF 135 Gas engine. Tried to bush hog and PTO kept disengaging. I can hold lever back and it will stay in gear. What should I do? Thanks
   / MF 135 PTO disengaging #2
When you engage the pto do you feel something pop like a de-tent (like the shifter does when you change gears?) If not the detent is stuck, or it possibly popped out.
No de-tent like feeling. It does not feel like it goes in as far as a gear shift or as far as when I put it in Ground position. Where can I find out how to chech detent? Bush hogged with it today. Used a tarp strap to hold it in gear.
   / MF 135 PTO disengaging #4
The detent is in the side cover where the pto lever is, when you take the pto cover off some of the transmission/hydraulic fluid will come out (take the bottom bolt off of the pto cover, and let it drain from there first) you will need a good sized drain pan.
If you need the detent parts
191221M1 Spring (15/32 x 1-3/16")
180418M1 Plunger (1/2" Dia. x 51/64")
Thank you. It does not sound to difficult. I plan on buying repair manuals for tractor. Is Jensales package for about $180 good?
   / MF 135 PTO disengaging #6
I have the Jensales operator, service and parts manuals for the 135. They are OK--better than the I&T manuals I have for the 135.
I'd recommend getting the manuals from Agco.
   / MF 135 PTO disengaging #7
The original MF 135 manual is good, but the I&T manual is a good addition to the original MF manual (I have both).
   / MF 135 PTO disengaging #8
The jensales manuals are AGCo reprints so they will work just fine.
I just bought some from Yesterdays Tractors. Service manual and part manual. $99. Hope to work on it soon. Thanks for help.
(8) DRAWER METAL TOOLBOX (A51248)
(8) DRAWER METAL...
2020 JOHN DEERE 7R210 LOT IDENTIFIER 161 (A53084)
2020 JOHN DEERE...
Ranger Welder (A52377)
UNUSED AGT MXCRT23 STAND ON SKID STEER (A51247)
UNUSED AGT MXCRT23...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
