MF 135 Perkin 3 cyl Diesel sitting for 20+ years
   / MF 135 Perkin 3 cyl Diesel sitting for 20+ years #1
briaineo
Ireland
MF 135
Hello from Ireland
I'm trying to get a 1960's MF 135 going again it been sitting at least two decades and is seized solid.
Been pouring different solutions down the cylinders for months now and trying to turn the fly wheel, to no avail.
I致e never delved into an engine before rebuilt control valves and brake callipers or old cars before that's about it.
Have the diesel tank off and the oil drained (total sludgy gunk mixed with water)
I have the three injectors removed and got them rebuilt.
I was going to buy an engine overhaul kit and remove the liners and replace the pistons and rings.
Can anyone help with the order/process please?
Below is what I think I should be doing;
1. Remove rocker cover then, cylinder head (undo bolts)
2. Remove oil sump (undo bolts)
3. Disconnect conrods (undo bolts)
4. Push pistons out through top of block (is this done by hammering up a length of wood from below? (only going from videos online)
5. Remove cylinder liners (seen a video online where a guy used a homemade jig: a threaded bar with a circular disc he machined on a lathe attached to the bottom and was able to slowly prise them upwards by turning the nut which rest upon two pieces of angle iron up top)
6. Does the MF 135 have rubber seals that go in before the new liners do?
7. What would the correct method be for home installation of the new liners? Reverse of removal? Or is the crank shaft in the way?
Leaving the Cylinder Head and valves etc aside for the moment
Reinstallation
New sleeves in
1. Install the 5 rings on the pistons (are all the rings the same?)
2. Drop in the pistons
3. Connect up con rods to correct toque settings
4. Replace sump cover (replace oil pump?)
5. New head gasket if using a copper one is gasket sealant required?
6. Install cylinder and torque up bolts to correct setting
I've probably missed loads any advice would be great
Two torque settings I don't have are the cylinder head bolts and the con rod bolts
Thanks
   / MF 135 Perkin 3 cyl Diesel sitting for 20+ years #2
   / MF 135 Perkin 3 cyl Diesel sitting for 20+ years #3
The clutch could be stuck to the flywheel. Have you checked for this problem?
Good luck
Thanks jeff9366
Hi flusher
I haven稚 checked if clutch is stuck to the flywheel; is there an easy way to check this?
Thanks
   / MF 135 Perkin 3 cyl Diesel sitting for 20+ years #5
Even if the clutch is stuck to the flywheel, the engine should turn if the transmission is in neutral. I start the Perkins in my Fordson Super Dexta frequently with the transmission in neutral standing beside the tractor and the clutch is engaged when I do that. You need to get a manual, it's an easy engine to work on, but a manual is absolutely necessary. Water in the oil pan is not a good sign, could be cracked block or head. You need to dismantle the engine to figure out what is wrong. You have a very tough engine in that old Perkins, though, don't write it off until you figure out what's wrong with it. I wouldn't buy any more parts yet, if I were you.
   / MF 135 Perkin 3 cyl Diesel sitting for 20+ years #6
Could also try to drag it, use the drivetrain's gearing to apply more force to the engine than you can put on it at the flywheel.
   / MF 135 Perkin 3 cyl Diesel sitting for 20+ years #7
I tried that dragging approach once on a friends vintage tractor that had only been seized a short time. Surprising to both of us, it was totally ineffective. AND, that was after having brake fluid in the cylinders for a while.
   / MF 135 Perkin 3 cyl Diesel sitting for 20+ years #8
one of these methods will work, you just need to be careful for safety, and mind how long the acid stays in the cylinder!.. Broken Tap Removal by chemical methods basically, it's the same as removing a tap, you want to dissolve just enough material to loosen the cylinder, then neutralize the acid..
   / MF 135 Perkin 3 cyl Diesel sitting for 20+ years #9
Brake fluid??? why aren't u using transmission fluid?? ATF will eat the carbon deposits..
Most everyone uses ATF & acetone mix 50/50 & let it sit about a week..
I noticed u got the injectors rebuilt.. why not the pump?? The injectors aren't any good without the pump..
I can help u out with the pump rebuild.. BUT u gotta get the engine to turn 1st.. BUY A BOOK/ SERVICE MANUAL..
Hi
Just a quick question on the sleeve removal, saw a great homemade jig made up using a treaded bar.
Is the diameter at the top of the sleeves the same as the bottom? Was thinking of getting a disc made up on a lathe but wanted to get a disc made before the new sleeves are ordered. Like in image attached: Automotive or Tractor cylinder crank in sleeve puller | eBay
Thanks
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
2020 Ford Transit 250 Cargo Van (A51692)
2020 Ford Transit...
2018 Bobcat T590 (A50123)
2018 Bobcat T590...
