mf 135 lift arms wont come down
   / mf 135 lift arms wont come down #1
ohiogary
Martins Ferry , Ohio
MF 135
The other day I was using my mf 135, and when I lifted the blade the arms would not come down, I removed the side plates, but not sure what to look for, when I move the levers, I can see two pins with springs moving, but cannot tell if something has come loose, anybody have a similar problem
Gary
   / mf 135 lift arms wont come down #2
Check for a knob centered below the seat that adjusts the pto descent rate. It can get turned by accident and can lock the 3pt in the up position.
We really need a graphic of this.
   / mf 135 lift arms wont come down #3
No PTO decent knob on the 40 year old Massey. Decent is controlled by the same lever that is not working for the OP. I have read much in the past when I first got my 135 but forgotten most of it. You should be able to google for an answer as I recall reading lots because while I can raise and lower the 3PTH on mine, the other (draft?) control is seized up and I once thought about going in and fixing it and my weak hydraulic system.
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A52706)
2019 CATERPILLAR...
2005 TerraGator 8104 (A55301)
2005 TerraGator...
30ft Highway Trailer Co. Lowboy (A55218)
30ft Highway...
2000 GMC C7500 CRANE TRUCK (A51406)
2000 GMC C7500...
