mf 135 lift arms wont come down
   / mf 135 lift arms wont come down #1
ohiogary
Martins Ferry , Ohio
MF 135
The other day I was using my mf 135, and when I lifted the blade the arms would not come down, I removed the side plates, but not sure what to look for, when I move the levers, I can see two pins with springs moving, but cannot tell if something has come loose, anybody have a similar problem
Gary
   / mf 135 lift arms wont come down #2
Check for a knob centered below the seat that adjusts the pto descent rate. It can get turned by accident and can lock the 3pt in the up position.
We really need a graphic of this.
   / mf 135 lift arms wont come down #3
No PTO decent knob on the 40 year old Massey. Decent is controlled by the same lever that is not working for the OP. I have read much in the past when I first got my 135 but forgotten most of it. You should be able to google for an answer as I recall reading lots because while I can raise and lower the 3PTH on mine, the other (draft?) control is seized up and I once thought about going in and fixing it and my weak hydraulic system.
Electric Mobility Scooter (A51694)
Electric Mobility...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A54814)
2021 International...
UNUSED LANDHONOR FW-13-15000G HYD WINCH (A54757)
UNUSED LANDHONOR...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A55301)
2012 NEW HOLLAND...
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A54757)
UNUSED IRANCH SEMI...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
