MF 135 hydraulics
/ MF 135 hydraulics #1
porthlow
scilly
mf 135
I have a c1967 Massey Ferguson 135 chassis number 16752
The hydraulics for the three point linkage work but have become very weak in its lifting capacity.
It will lift an empty transport/link box normally, but if I load it it fails to lift. If I assist it by doing some of the lifting myself it will lift but drop when I let go.
The oil is at the correct level
What parts are likely to need replacing please, and is this a straight forward job?
/ MF 135 hydraulics #2
Some internal adjustments I belief wil do the trick .
Is there a lot of play on the toplink connectingpoint ?
/ MF 135 hydraulics
Thanks for your reply,
The top link doesn't seem particularly sloppy, but I have tried lifting a load without the top link attached and was able to lift for the front of the tractor to lift off the ground.
What adjustments can be made to the top link attachment please
/ MF 135 hydraulics
sorry, I missed a bit of text
The top link doesn't seem particularly sloppy, but I have tried lifting a load without the top link attached and was able to lift a load heavy enough for the front of the tractor to lift off the ground.
24in excavator tooth bucket (A61307)
24in excavator...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
