MF 135 gas, bogs down under load help
   / MF 135 gas, bogs down under load help #1
sch2046
massey ferguson 135
I had the carb rebuilt last year, ran great. Now it starts and idles fine, as soon as I put it in gear and let the clutch out, it sputters and wants to die........could it be as simple as a fuel filter? Is there a fuel filter?
Thank you in advance.
Sean
   / MF 135 gas, bogs down under load help #2
My guess is clogged carb jet.
Fuel filter: should be easy to spot. If there's no such filter, I'd clean the fuel tank and the lines and then install that filter. Easy job. Not expensive. Then pull the carb, clean the jets, check the float and float valve/seat.
Good luck.
   / MF 135 gas, bogs down under load help #3
I put one of those universal in-line fuel filters that you can see into on mine. Under the fuel tank there should be one of those glass sediment bowl with a screen that needs to be cleaned out time to time.
   / MF 135 gas, bogs down under load help #4
You also might want to check the fuel line where it passes by the battery tray/fuel tank mount. Mine had the same problem, found the battery tray had worked loose and was flattening the steel fuel line. Good luck
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53472)
2016 RAM 5500...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
2022 New Holland Workmaster 40 Tractor with Loader (A51573)
2022 New Holland...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
Wanco 800W Solar Integrator Trailer (A51691)
Wanco 800W Solar...
