MF-135 Engine Swap.............
   / MF-135 Engine Swap............. #12
When you fit the rope seal , if you have a "tail" left over, it should be pulled out and refitted. You need to pack it in HARD to make it fit correctly.
NOTE when you go to split the tractor wedge the front axle first, so the engine does not flop over.
OK , Will do ! Perhaps I may have fallen short in the rush on my first attempt. I have ordered the "UK made" replacement seal this time. Thanks for the "wedge" tip......... normally, I would have left it hung on the crane to prevent that issue....
   / MF-135 Engine Swap............. #14
Ralex1, the reason for the wedge is because, usually the front end is lighter to roll forward. In this part of the country most tractors have liquid filled back tires. Hanging the front in a crane means you need to roll the rear section back, and my mechanic friend says the weight means the rear can be frustrating to realign compared to the lighter front end.
Good luck.
2007 CHEVROLET SILVERADO 4X4  DUALLY TRUCK (A51222)
2007 CHEVROLET...
Toro Workman Cart (A50322)
Toro Workman Cart...
Ranch Hand Pickup Truck Grill Guard (A49461)
Ranch Hand Pickup...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2024 Iron Bull 20ft T/A Equipment Trailer (A49461)
2024 Iron Bull...
16 STEEL SHEETS CURVED (A50854)
16 STEEL SHEETS...
