MF 135 - Can the PSI be adjusted on the Power Steering Pump?
   / MF 135 - Can the PSI be adjusted on the Power Steering Pump? #1
p3210
1971 mf135
Hi Folks
I acquired an MF135 (1971?). The original power steering pump failed. I replaced it with a genuine MF power steering pump (part 773126v92) from a Massey Ferguson autherized repair shop.
Question - Is there a mechanism on the pump to make it possible to lower the PSI on this pump? Can I adjust a nut or screw on the relief valve?
Apparently this new pump puts out 1500 PSI. The original pump was rated at 1175 PSI.
I'm having problems with seals blowing out (last one was associated with the rod in the power steering cylinder). I have read about installing a bypass hose in the steering column to releave pressure; which I might do. But wondering if I can lower the pressure at the pump.
Any thoughts greatly appreciated.
Thansk!
Phil
Thanks - Yep, I asked the shop to take a look at the old pump and rebuild.... they inspected the old pumt, pointed out the worn metal and said it was too far gone.
   / MF 135 - Can the PSI be adjusted on the Power Steering Pump? #4
I'm with pmsmechanic. I would ask the shop that did the work if there is a way to lower the pressure.
I have a 135 and have always had problems with leaks. I have done several seal replacements and leaks persist. Others have reported similar experiences. I am resigned to just adding more fluid.
   / MF 135 - Can the PSI be adjusted on the Power Steering Pump? #5
There should be a threaded plug on the side of the power steering pump. If you remove the plug there should be a spring inside pushing on a sliding piece that fits precisely in the bore of the hole. There might be some shims by the spring on either end. If you remove the shims or install a spring with less tension the pressure should go down as the sliding plug and spring regulates the pressure of the hydraulic system.
If you decide to lower the pressure be very careful to install everything back exactly the way you removed it. In fact I wouldn't remove the sliding plug at all. All you need to work with is the spring and shims.
Good Luck!
Edited to add that I might have a service manual for a 135 at home. When I get back home I'll have a look and see if there's a picture of the power steering pump. If it looks like I forgot to look and mention something on this thread, I have. Please don't be shy about reminding me in a couple of days.
Thanks GeorgiaRebel - Unfortunately the leak more of a constant flow. I wish it was a slow leak that I could just refill the pump at the end of the day....
Good Luck!
Thanks pmsmechanic. There is a "relief valve" which sounds like the plug with spring you mentioned. I was hoping that the valve might be a way to lower the PSI.... I think I still have the original pump... I wonder if I can just change springs. Thanks again!
JOHN DEERE 1705/6700 LOT IDENTIFIER 20 (A53084)
JOHN DEERE...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2024 JOHN DEERE 331P-TIER SKID STEER (A51246)
2024 JOHN DEERE...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A53472)
2024 BCL...
2012 Ford F-250 Pickup Truck (A51692)
2012 Ford F-250...
Unused 2025 Spirit Mini Golf Cart (A51694)
Unused 2025 Spirit...
