Hi Folks
I acquired an MF135 (1971?). The original power steering pump failed. I replaced it with a genuine MF power steering pump (part 773126v92) from a Massey Ferguson autherized repair shop.
Question - Is there a mechanism on the pump to make it possible to lower the PSI on this pump? Can I adjust a nut or screw on the relief valve?
Apparently this new pump puts out 1500 PSI. The original pump was rated at 1175 PSI.
I'm having problems with seals blowing out (last one was associated with the rod in the power steering cylinder). I have read about installing a bypass hose in the steering column to releave pressure; which I might do. But wondering if I can lower the pressure at the pump.
Any thoughts greatly appreciated.
Thansk!
Phil
Thansk!
Phil
