MF-135 auxiliary hydraulic?
   / MF-135 auxiliary hydraulic? #1
flusher
Super Member
Sacramento
Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
Has anyone out there rigged up auxiliary hydraulic ports on the MF-135?
I have Big Gene Austin's CD on the MF-135 and it includes a ton of info on remote hydraulics. I haven't had time to wade through all of it.
Just looking for info from someone who's actually tried to do this.
Is there a simple way to do this?
Thanks in advance.
   / MF-135 auxiliary hydraulic? #2
Yes there is an easy way to do it , email me at lowerlakeranch@telus.net and i will send you a pic. showing how i did mine. I couldn't figure out how to upload one on here. JJ.
   / MF-135 auxiliary hydraulic? #3
Thanks in advance.
Got 'em on my 150. (same basic tractor) There's a "plate" under the front of the seat that replaces with a "diverter valve". From there, a couple hoses connect to a control valve. Then 2 hoses to the rear remote quick couplers. Piece of cake. Your internal pump is relatively small (4.5 or 4.6 GPM) but will operate most anything that a tractor of that size will handle.
TISCO sells a kit that includes everything you need, including all hoses with correctly oriented ends and fittings. Last one I bought (to install on a friends 135) sold for around $400. Any dealer will have access to TISCO (a division of Woods)
   / MF-135 auxiliary hydraulic? #4
OK lets try this posting picture thing again:confused:
   / MF-135 auxiliary hydraulic? #5
JJ, is that a kit? How much was it?
   / MF-135 auxiliary hydraulic? #6
No not a kit, the tractor had the diverter valve already on the lift cover, i just bought the the spool valve, hoses and quick disconnects, made up a tall bracket that bolts onto the footplate for the spool valve to sit on and another bracket bolted to the side of the diff. for the QD's. Total cost about $300. JJ.
   / MF-135 auxiliary hydraulic? #7
Nice set up. I did not know where to run the return line for a double acting cylinder.
   / MF-135 auxiliary hydraulic? #8
I'll try to remember to get a picture of the set-up on my 150 Massey. It has the return line hooked to a return port on the diverter valve.
It's the "TISCO" kit I was talking about earlier in the thread. Most of our local Massey dealers use it as a retro-fit kit for all MF utilities from 100 series on up to very recent models. It even comes with all the bolts and spacers to attach valve to fender.
I changed that a bit. Made a bracket that attaches to tractor chassis to hold valve. I HATE drilling holes in fenders.
   / MF-135 auxiliary hydraulic? #9
Hello,
I thought I had found a solution by using a double acting spool working from my MF135 so that I could operate a 3 point attached tipping bucket with hydraulic up and down RAM.
I have just been told/advised that on the MF135 its not possible to have independant movement of the 3 point linkage at the same time as operating the DA spool valve to move the ram up and down... does this seem right?
this is what i have bought, can it be used on a MF135?
   / MF-135 auxiliary hydraulic? #10
I'm afraid it's right. On my MF35 I had changed the plate under the seat where the hydraulic oil arrives from the pump for a 3 way valve. With the handle forward I could use the FEL, with the handle up I used the 3 pt hitch and with the handle towards the rear I operated the trailer. These were all single effect cylinders, up under pressure and down under their own weight. There was no way I could use the 3 pt and the FEL at the same time for instance.
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A50322)
2017 Toro Z-Master...
2016 E35 Bobcat Mini Excavator (A50322)
2016 E35 Bobcat...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
YOKOHAMA - GALAXY 16.9-24 DIAMOND BUTTON TIRES (A52748)
YOKOHAMA - GALAXY...
