MF 1260 / AGCO ST40x Moving Hay
   / MF 1260 / AGCO ST40x Moving Hay #1
Cowboy65
Does anyone have experience using a MF 1260 or AGCO ST40x (equivalent tractors) to move large (5x6 or 6x6) round bale hay? I know that bale weight varies depending on moisture, tightness, etc. so for the purpose of discussion let's say that the bale weight is 1500-1800 lbs.
Can the FEL handle this weight for limited use or will the bales have to be moved using the rear lift for this size tractor.
   / MF 1260 / AGCO ST40x Moving Hay #2
my 1240 handles em okay if its not too muddy..2wd dont git along good in sugar sand or mud...leave the bushhog on the back to cntr the weihgt
   / MF 1260 / AGCO ST40x Moving Hay #3
I have a 1260; I move a lot of good size logs a bolders using a heavy duty grapple with no problem. As dieselbeef notes above, be sure to counter weight with something heavy on the back.
   / MF 1260 / AGCO ST40x Moving Hay #4
on a side note...my wiring harness for the pto caught fire...the tech said thats common when bushoggin...just a head up for ya
i just bought this tractor so id have been pissed but i had been mowing for 3-4 hrs when it happened so i cant really blame the prev owner...
   / MF 1260 / AGCO ST40x Moving Hay #5
The 1260 will handle a 4x4 and lighter 4x5. Anything larger you can't lift. This is with the loader.
FRONTIER  ROUND HAY BALE SPREADER (A52472)
FRONTIER ROUND...
2014 FORUM HORIZONTAL 3 PHASE SEPARATOR (A52472)
2014 FORUM...
2012 DOOSAN G25 GENERATOR (A52472)
2012 DOOSAN G25...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
2019 FORD TARNSIT CONECT CARGO VAN (A52577)
2019 FORD TARNSIT...
