MF 1246 loader problem
   / MF 1246 loader problem #1
merlintractor
Bronze Member
Colorado Front Range
MF 1260
I have a MF 1260 with a 1246 loader. I have a leak developing where the joystick plate mounts to the control head (loader mounted control head). Before I go tearing into the control head, I had a few questions:
-Where can I find an exploded view of the control head parts?
- It looks like the original seal was something like RTV; is that correct or is there some sort of gasket I should be using? (From the looks of it, the previous owner did some DIY work on the hydraulics).
-Once I pull this plate off, what should I expect...will a bunch of springs and such come flying out at me?
-After I reseal the leak and assemble the control unit do I need to bleed the system?
Thx
   / MF 1246 loader problem #2
Check out this post.... Maybe it will help.
http://www.tractorbynet.com/forums/massey-ferguson-owning-operating/93420-1246-loader-mf.html
68642d1169307935-1246-loader-mf-nimco-joystick-valve-1466-jpg
Here is another post that may help.
http://www.tractorbynet.com/forums/massey-ferguson-owning-operating/277931-loader-valve-leak-mf1240.html
AIRMAN POS100S PORTABLE AIR COMPRESSOR (A52472)
AIRMAN POS100S...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
1262 (A50490)
1262 (A50490)
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
