MF 1246 Bucket Raining on its own.
   / MF 1246 Bucket Raining on its own. #1
huntin4bass
My 1246 Loader is raising on its own. If I push up slightly on the control stick it stops. I have had the valve apart and it all looks good, no broken seals or signs of wear. I am also trying to find a exploded view of the controller without any luck, it is manufactured by Cross.
Thanks in advance for any ideas.:confused2:
   / MF 1246 Bucket Raining on its own. #2
The ball joints or at least one ball joint are in a bind on the controller. Just barely loosen the bolts that are in the end on the ball joints. Lightly jiggle the handle. Then tighten the bolts back down. That should solve the problem or that is the least expensive solution.
2017 Ford Taurus Sedan (A51694)
2017 Ford Taurus...
2001 John Deere M665 (A50120)
2001 John Deere...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
2020 COLOMBO TM LOT NUMBER 192 (A53084)
2020 COLOMBO TM...
2022 CATERPILLAR 301.7CR EXCAVATOR (A51246)
2022 CATERPILLAR...
