MF 1246 Bucket Raining on its own.
   / MF 1246 Bucket Raining on its own. #1
huntin4bass
My 1246 Loader is raising on its own. If I push up slightly on the control stick it stops. I have had the valve apart and it all looks good, no broken seals or signs of wear. I am also trying to find a exploded view of the controller without any luck, it is manufactured by Cross.
Thanks in advance for any ideas.:confused2:
   / MF 1246 Bucket Raining on its own. #2
The ball joints or at least one ball joint are in a bind on the controller. Just barely loosen the bolts that are in the end on the ball joints. Lightly jiggle the handle. Then tighten the bolts back down. That should solve the problem or that is the least expensive solution.
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
John Deere GR72B 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
John Deere GR72B...
Adams 5 ton Fertilizer Buggy / Wagon (A53472)
Adams 5 ton...
SET OF 51" HANG ON WHEEL LOADER FORKS (A51246)
SET OF 51" HANG ON...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
