MF 1235 3 cylinder diesel iseki engine
   / MF 1235 3 cylinder diesel iseki engine #1
cowalker
Massey Ferguson 1235
I have a MF 1235 3cyl. diesel iseki and it only has 10 lbs of oil pressure. My question is: What is the operating oil pressure supposed to be? I have changed the filter and put in a new gauge.
   / MF 1235 3 cylinder diesel iseki engine #2
Was the gauge you installed electric? If it was maybe the sender is bad. When changing electric gauges it is always a good idea the buy the matched sending unit and change both out. You could always attach a known good mechanical pressure gauge temporarily to the engine and then you would know for sure what the oil pressure is.
   / MF 1235 3 cylinder diesel iseki engine #3
I dumped the idiot lights and installed all mechanical gauges on my ISEKI 3 cyl. diesel.....it sure helped alot when I decieded to sell my tractor....it always run about 40 lbs or more when warmed up to operating temp.....oil pressure will drop somewhat.....10 lbs sounds a little on the low side....is this is what it reads on cold start up?...or is it 10 lbs after it reaches operating temp? anyhow just me sticking my nose into the forum again....Ampa<>
   / MF 1235 3 cylinder diesel iseki engine #4
I have lots of Iseki engines if anyone needs one.
   / MF 1235 3 cylinder diesel iseki engine #5
i am looking for a good 1300 series deisel motor for a iseki tractorif you have one i would appreiate you notifing me about thank you
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
2011 PETERBILT 367 TRI-DRIVE WITH TAG (A52472)
2011 PETERBILT 367...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
Fire Truck (A51692)
Fire Truck (A51692)
ROCK PICKER (A52472)
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
