MF 1100 Tractor
   / MF 1100 Tractor #1
Pedrojoe
Beaumont, Texas
MF 1100
My Massey Ferguson 1100 tractor has no hydraulics. All at once no signs the hydraulics quit. Changed and cleaned both filters on the hydraulics. Took the charge pump off. Charge pump has all parts a moving. No keys are sheared off. Just puzzled.
   / MF 1100 Tractor #2
The is a little tiny shaft coupler inside the transmission that has more than likely sheard off the splines. My MF 1155 did this 3 time before i got rid of it. It connects the front shaft from the flywheel to the rear shaft that turns the pto and charge pump. All 3 time i had to replace the coupler and rear shaft. Just the parts were expensive but getting to it was the nightmare. The transmission has to split right in the middle. Call the mf dealer or abiline machine for help diagnosing the problem to be sure. If it is what i think it is. Abiline machine has the parts much cheaper now. Shaft part # am503433m1
Coupler # am516006m3
Get you a s I&T shop manual from abiline machine too. They are only 31 dollars
   / MF 1100 Tractor
Also my PTO clutch moves freely in and out of gear
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53473)
2016 RAM 5500...
2025 KG43 UNUSED Chain and Ratchet Binder Set (A53117)
2025 KG43 UNUSED...
2019 FREIGHTLINER M2 26' BOX TRUCK (A51247)
2019 FREIGHTLINER...
Used 20' Container Box (A52384)
Used 20' Container...
