MF 1100 & 165
   / MF 1100 & 165 #1
RyanL
Caldwell, Ohio
MF 1540 4wd,loader, R-4s
   / MF 1100 & 165 #2
I think they are gona want about 45 for the 165 also. 4500 for the 1100 is a real good price if every thing works. either was a good tractor,somtimes the dual power will go out but you still can operate the tractor.just don't have the spliter gears, similar to the tourque amplifier in the IH,not a big deal, If they even have that option.
   / MF 1100 & 165
Here is a link to the 1100. http://www.fastline.com/item.asp?itemno=3965972
I haven't seen it up close, but looks good in photo. The 165 i think they wanted $4,500 for it but couldn't sell it cause it has a few minor problems, so they are lowering price.
   / MF 1100 & 165 #4
Both are good solid tractors. If you need the size and hp of the 1100 then the deal sounds good if the tractor passes inspection. If the 165 is in that bad of shape,look around for another one. Plenty of them out there.
   / MF 1100 & 165 #5
Having the Square rear axle is a indication of being made in the early seventies--the round axles could be from mid sixties era--If the either has Multipower and it is out or going out--I would pass at any price--they will freewheel and not hold a load back when this is not functioning--Very dangerous--Ken Sweet
Sweet Farm Equipment LLC *New and Used Tractors for 27 years*
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A52377)
2011 Kenworth T300...
INOP/NON-RUNNING 2005 Toyota Prius Passenger Car, VIN # JTDKB20U253038319 (A51572)
INOP/NON-RUNNING...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
