MF 1080 Tach or Tach Cable?
   / MF 1080 Tach or Tach Cable? #1
BCMac
Horsefly, BC
John Deere 3255, Massey Ferguson 35, Massey Ferguson 1080, Ford 8N, John Deere D110
The tach on our MF 1080 doesn't work. Basically the needle bounces from zero to a bit above when the engine revs, but it seems like it has more to do with the vibrations of the tractor than anything else. It is never steady anywhere except zero at idle.
Is there any way determine the cause? The tach itself or the cable? Or something else I am not thinking of?
   / MF 1080 Tach or Tach Cable? #2
One way would be to remove the cable from the tractor and spin the cable, see if you can feel any hard spots when you turn the cable. The cable could just need to be lubed, or replaced. If the cable feels good you could spin the cable with a drill while it's hooked to the tach, and bump the dash by hand to see if changes (needle bouncing around while you bumping the dash) then I would say it's the tach.
Thanks Kenneth. I will give that a try when I get back to the farm on Thursday. I figure it's one or the other, and frankly on a 45 year old tractor, might just be worth replacing them both anyhow.
   / MF 1080 Tach or Tach Cable? #4
I'm 49 years old, and could stand to have a couple of parts replaced myself LOL.
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
2004 Kia Optima Sedan (A51694)
2004 Kia Optima...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500 4x4...
20' BI-PARTING GATE (A51248)
20' BI-PARTING...
