MF 1030 Water in Transmission oil, Drained Refilled, Still no Htd pressure
   / MF 1030 Water in Transmission oil, Drained Refilled, Still no Htd pressure #1
etbrown
mf 1030
Like many others, looks like my shifter boot let rain water into the tranny for many years, and I had the dreaded white oil, and recently lost hydraulic pressure. I'm sure it had water in there for years though worked properly until now.
Changed the oil and filter, still no pressure.
Suggestions appreciated
   / MF 1030 Water in Transmission oil, Drained Refilled, Still no Htd pressure #2
:welcome:
To the TBN forum Mr. Brown.
One of the MF people will be along soon to help.
   / MF 1030 Water in Transmission oil, Drained Refilled, Still no Htd pressure #3
Have you checked the oil since you changed it? Very possible there was enough contaminated oil in the hoses and cylinders to contaminate the new oil. It is possible pump or something was damaged by water in the system.
   / MF 1030 Water in Transmission oil, Drained Refilled, Still no Htd pressure #4
If you just changed the screw on hyd oil filter then there may be another. MF may be different than my JD 4300. In mine there is a filter inside the trans (not the external hydraulic oil filter that is screwed on) where the hose is connected to the trans that was clogged caused from water in oil. It was a fine mesh filter about an inch in diameter about 12 inches long. Look at yours and see if there is a filter where the hose connects to the trans.
   / MF 1030 Water in Transmission oil, Drained Refilled, Still no Htd pressure #5
On the JD 310B backhoe water kept being pushed to the sump so I started to loosen that drain plug and let the water out and screw it back in when the oil started flowing. It was my guess all the cylinders had water in them and over time it worked back to the sump. That was 6-7 years ago and the last time I checked the fluid was water free.
   / MF 1030 Water in Transmission oil, Drained Refilled, Still no Htd pressure #7
Has anyone experienced the white oil on a MF compact? Interested to know the steps taken.
   / MF 1030 Water in Transmission oil, Drained Refilled, Still no Htd pressure #8
Drain, fill, use and dump, a few times to remove the water contaminated oil. If you have loader or accessories, they need the same treatment. Ensure you drain fully from all low points like axle housings or driveshafts if you have them. if it's been in there for years, there is probably a lot of sludge to get out.
   / MF 1030 Water in Transmission oil, Drained Refilled, Still no Htd pressure #9
Do you have hydraulics again? What hydraulic implements do you have? Have you checked parts layout for any screens?
   / MF 1030 Water in Transmission oil, Drained Refilled, Still no Htd pressure #10
Only implement is loader.
Anyone know if this Japanese Massey has any screens?
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
JOHN DEERE 461R LOT NUMBER 61 (A53084)
JOHN DEERE 461R...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
2014 Dodge Grand Caravan SE Van (A51694)
2014 Dodge Grand...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
