MF 1030 pto won't engage
   / MF 1030 pto won't engage #1
DIMM
MF 1030
When tractor is running can't engage pto , shut it off engage it and works fine. Any advice ?
   / MF 1030 pto won't engage #2
Welcome to the Forum!
I'm not familiar with your tractor but many "Live" PTO tractors require the clutch to be depressed halfway to engage. Or, Perhaps the clutch disk(s) are stuck together from not being used.
   / MF 1030 pto won't engage #3
What specifically happens when you try to engage PTO with engine running? If you get grinding follow Tinhack's post. What happens if you engage PTO with engine off then start engine? Does PTO remain engaged or drop out? A better explanation on symptoms could lead to better suggestions for a solution.
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2011 TROXELL 130BBL (A52472)
2011 TROXELL...
2012 Ford F-450 Altec AT200A 30ft Bucket Truck (A50323)
2012 Ford F-450...
2013 Freightliner M2 106 Altec AA755 55ft Bucket Truck (A50323)
2013 Freightliner...
2002 Kountry Star Motorhome (A50324)
2002 Kountry Star...
2015 John Deere X300 (A50121)
2015 John Deere...
