MF 1030 pto won't engage
   / MF 1030 pto won't engage #1
DIMM
MF 1030
When tractor is running can't engage pto , shut it off engage it and works fine. Any advice ?
   / MF 1030 pto won't engage #2
Welcome to the Forum!
I'm not familiar with your tractor but many "Live" PTO tractors require the clutch to be depressed halfway to engage. Or, Perhaps the clutch disk(s) are stuck together from not being used.
   / MF 1030 pto won't engage #3
What specifically happens when you try to engage PTO with engine running? If you get grinding follow Tinhack's post. What happens if you engage PTO with engine off then start engine? Does PTO remain engaged or drop out? A better explanation on symptoms could lead to better suggestions for a solution.
2018 Dodge Grand Caravan SXT Van (A50324)
2018 Dodge Grand...
Krone Swadro 46T (A50120)
Krone Swadro 46T...
John Deere 7200 Max Emerge II 16 Row Corn Planter (A52349)
John Deere 7200...
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
(4) Rolls of Barb Wire (A50515)
(4) Rolls of Barb...
UNUSED CFG INDUSTRIAL STSD10 QUICK ATTACH SEEDER (A51244)
UNUSED CFG...
