MF 1020 won't start
   / MF 1020 won't start #1
SGOTS
Palmetto, GA
MFN 1020
Have a MF 1020 and the starter will not engage. Gear selector is in S. PTO is off. Is there another starter cut-out?Battery has good charge & glow plugs are pulling a load. Elec system is otherwise normal. I have a nagging feeling, I have missed another cut-out switch. Any ideas?
   / MF 1020 won't start #2
Welcome to the forum. There is a safety switch that is activated when clutch is depressed.
Thanks Mike. I should have remembered to add that I had the clutch depressed. I had this rig parked for about 6 weeks and I often leave the PTO engaged for additional " security". I have this nagging feeling I left another starter cut-out switch open. I just can't remember what it might be......argh.
While jumping my starter, I discovered two things:
1. The starter spun fine but was not engaging the eng.
2. The starter solinoid had a disconnected electrical wire.
Reconnected the solinoid bayonet and she is back in service.
Not sure if I had pulled that wire but I'm reminded; "I'll never remember the things I've forgot."
Thanks for your help Mike.
   / MF 1020 won't start #5
A disconnected wire is the hardest thing to see. On my 1020 the wire that goes into the ground connector is loose. Sometimes if it won't start I have to give it a wiggle. It like a added security feature.
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52748)
John Deere 6105E...
PIPE TRAILER (HOMEMADE NON TITLED) 28FT (A52472)
PIPE TRAILER...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
PRESSURE WASHER GAS (A52472)
PRESSURE WASHER...
2012 RAM 5500 (A52472)
