MF 1020 won't start
   / MF 1020 won't start #1
SGOTS
Palmetto, GA
MFN 1020
Have a MF 1020 and the starter will not engage. Gear selector is in S. PTO is off. Is there another starter cut-out?Battery has good charge & glow plugs are pulling a load. Elec system is otherwise normal. I have a nagging feeling, I have missed another cut-out switch. Any ideas?
   / MF 1020 won't start #2
Welcome to the forum. There is a safety switch that is activated when clutch is depressed.
Thanks Mike. I should have remembered to add that I had the clutch depressed. I had this rig parked for about 6 weeks and I often leave the PTO engaged for additional " security". I have this nagging feeling I left another starter cut-out switch open. I just can't remember what it might be......argh.
While jumping my starter, I discovered two things:
1. The starter spun fine but was not engaging the eng.
2. The starter solinoid had a disconnected electrical wire.
Reconnected the solinoid bayonet and she is back in service.
Not sure if I had pulled that wire but I'm reminded; "I'll never remember the things I've forgot."
Thanks for your help Mike.
   / MF 1020 won't start #5
A disconnected wire is the hardest thing to see. On my 1020 the wire that goes into the ground connector is loose. Sometimes if it won't start I have to give it a wiggle. It like a added security feature.
1999 FORD F550 BOX TRUCK (A52577)
1999 FORD F550 BOX...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
16FT Flatbed Trailer (A51573)
16FT Flatbed...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A52748)
GALAXY - SET OF...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
