Metric V belts
   / Metric V belts #1
Pete Judd
Veteran Member
The Thin Gravy Ranch in The wet PNW
Yanmar 186d, JD 314
I have worn out the belts on the pto finish mower, and had to get a couple of replacements quick. Turns out the orignal where 16mmX1178MM, And the closet was a 64 X .50 inch. I expect a short life from these belts, am looking for a source of metric belts. I have googled the part # have come up with nothing,
   / Metric V belts #2
Are you sure you have the measurement correct? 178 mm is only 7 inches. I dont know your machine but isnt it more likely its 178 INCHES. (Even over here, in metric land, belts are still measured in inches.)
   / Metric V belts #4
This website might help you identify the belt you need. I've used it a few times. They are in the uk so buying from them is probably not an option. But once you have the belt code, you could google it to find a more local supplier.
High Quality Replacement V-Belts Major and Premier brands - Simply Bearings Ltd
I've bought from that same company on Ebay. Even including postage they were much cheaper than buying here in Australia. ($13 including postage for a 73 inch belt that was costing me about $30 over here!)
Oops I made a mistake. The UK company I purchased from was called Bearing Options on Ebay. A SECTION V BELT A16 - A46 VEE BELT 13MM X 8MM items in BEARING OPTIONS store on eBay!
   / Metric V belts #5
I just checked and the one I posted above has pretty cheap postage to the US if the OP isn't in a rush.
   / Metric V belts
Just a fyi, spent a couple of hours on the internet, and found out that the B that is before the number defines the angle of the V. The number with LI after it is the inside length. Found another number on the old belt with a LD after it was the outside length of the belt. Will get on the phone on Monday, with the local (50-100 miles away) industrial supplyers.
John Deere Bale Spear (A50515)
John Deere Bale...
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
2007 Peterbilt 335 Mickey AO-A Battery Truck (A50323)
2007 Peterbilt 335...
UNUSED TOPCAT QUICK ATTACH TREE SHEAR (A51244)
UNUSED TOPCAT...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52128)
2018 John Deere...
UNUSED CFG Industrial MY50R Mini Excavator (A47384)
UNUSED CFG...
