nwhitehill
I have a MK Martin Meteor 68 pull type snowblower. When using it the other day here in Southern NH to clear some wet, heavy snow it dug deep into the mud of my gravel driveway. The PTO shear bolt did it's job and sheared but I'm still unable to turn the impeller (fan) on the PTO side of the gear box. 've made sure there isn't still some kind of blockage between the impeller and housing. I've tried using a 4 foot bar to rotate the impeller but no luck. I'm thinking the gear box got destroyed before the shear bolt broke. The manual calls out P/N: 36132.
Does anyone have any suggestions as to what the problem might be if it isn't the gear box? If it is the gear box, what an equivalent part number / source might be?
Thank you for your help and input.
