Metal roof shed tie in????
   / Metal roof shed tie in???? #1
Ed of all trades
Elite Member
Waynesboro Va
John Deere X310, JD LA 145
I am adding a shed roof to the side of the shop. the A roof is a 4-12 pitch and the shed is mote like a 2-12 pitch. (I am guessing) I am using a 3' wide metal with ribs. I live in an area with some pretty good wends and want to know how to seal the lap between the shed and the A roof. Thanks Ed
   / Metal roof shed tie in???? #2
Flashing under the existing roof which overlaps your new roof. They sell foam rubber gasket material which sandwiches between the flashing and the new roofing preventing water infiltration.
Thanks Blackdog, I wondered if that was what I needed to do. Ed
   / Metal roof shed tie in???? #4
If you can't find the correct foam profile, strips of butyl tape will also get the job done. ABC supply will carry both products.
2016 Case CX160D Hydraulic Excavator (A51691)
2016 Case CX160D...
1988 BASSTRACKER 20' PONTOON BOAT (A51247)
1988 BASSTRACKER...
2014 716PT Homesteader 7'x16' Box Trailer (A52384)
2014 716PT...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
