Metal Post Driver
/ Metal Post Driver #1
W5FL
Central Texas
TYM T-1104/TX10 Loader Kubota M6800SD/LA1002 Loader Kubota RTV900
My dad is using a Metal Post Driver that hooks up to the three point and hydraulics. It is really heavy duty and drives a 4 inch steel post about 4 inches everytime it comes down.
Has anyone seen a driver like this that works on T posts. I will set the big posts in concrete if it costs more to drive them. Any ideas what an accessory like this costs or who makes them?
/ Metal Post Driver #2
wen,
Darn good tool, when setting many post's and the money is there. My nieghbor has the same that swings from the loader bucket. Mounted to 50HP Kubota. Drives a railroad tie like John Henry. Don't know the cost, will ask him. I seem to remember near $3000
Ask your Father. Can you make a metal cap that fits driver to T' post??? Short 4" pipe to go over the T' post???
Like, will the metal hand type fit the 3 point driver???
"What is a weed? A plant whose virtues have not yet been discovered."
Ralph Waldo Emerson (1803-1882)
/ Metal Post Driver #3
Wen, Danuser makes them, but I found out real quick they were out of my price range. But it sounds like it's the same thing your dad has, but with an adapter for the t-posts. I still have their literature, but forgot exactly what the price was. Try http://www.danuser.com
Bird
/ Metal Post Driver #4
Hey Wen ..for a dumb kiwi could ya tell me what a T post is:)we have a post here thats more of a Y than a T about 6foot long and (if you start at the bottom of the Y)1 1/2 by 1 by 1 (inchs)is that the kind of thing ya talking about driving??if it is kind of like that i's say it's faster driving them by hand (not with a hammer but a hand driver)we drive all our wooden posts with a big driver (400Lb hammer on it)and you could drive our Y posts with that by putting a 3-3 1/2 inch pipe about 4 foot long over top with a 5 inch X 1 inch plate welded on top ,i'd also make a frame out of 1 inch angle (like a pic frame)so i could put a bit of 2 inch thick wood on top(tight fitting!!) just to cut down the steel on steel noise .
CYA
JD Kid
/ Metal Post Driver
That is exactly what he did. He welded a pipe that fit over the T post and then a plate and a pipe to adapt it to the driver. He says it really works well. I sure hope when I am 85, I will still be driving T posts like he is doing every day! /w3tcompact/icons/smile.gif
/ Metal Post Driver
Thanks Bird. I found the Danuser site, but no data, just a description. "Under normal ground conditions, only a few strokes of the 235 lb. weight sets wood or steel posts firmly - and average size posts do not require pointing. Unit can be adjusted for driving posts perpendicularly on hillsides and in uneven ground. One PTO driven and two hydraulic models to choose from."
I probably couldn't afford it, but I believe I could get my money back pretty quick with the amount of fencing that is going on around my area. /w3tcompact/icons/smile.gif
/ Metal Post Driver
In California, I had a KIWI tree. They were nearly as good as Oranges.
T Posts are sold here as 1.25 #/ft and 1.33 #/ft and sound similar to identical to the Y post you are describing. They are made for barbed wire, but used for most Agricultural type fences here. Describe the 400 pound driver a little clearer to me. Is this a 390# man with a 10# sledge or a tractor implement. /w3tcompact/icons/wink.gif
The only driver I own is a piece of 4 inch pipe welded to some 1 in pipe handles. You pick it up and slam it down to drive the post a few inches at a time. Tried driving them with the loader just pushing them in the ground. Works pretty good on sand, but not to well on rocky soil.
There should be a cheap way to drive T posts with less effort than the manual drivers! /w3tcompact/icons/smile.gif
/ Metal Post Driver #8
i have a old one. It has a frame tha tfits on the 3pt. A weighted box rides on rails attached to the 3pt frame. A hydraulic cylinder is used to lift the weighted box, and then to release a trip lever which drops the box on the t-post. The box itself has a door which you put the t-post in; it holds it in line with the box.
I have had it for a year, but never got hydraulics. Now I have hydraulics sitting in the shop, but have not had time to mount them( adding tip/tilt to my B8200)
The concept looks correct. But, I have no data yet...
RobertN in Shingle Springs Calif
/ Metal Post Driver
RobertN,
If you run across a manufacturer or model number let me know.
I also saw a hydraulic operated hammer that they use on a backhoe or loader to bust rock. I bet that is another attachment that I would like to have and can't afford. /w3tcompact/icons/smile.gif
/ Metal Post Driver #10
Wen, I got Danuser to mail me their literature on the different models (no prices included), then I talked to my dealer, and now I'd be afraid to say anything about the price because I've forgotten, but it was well up there in the thousands of dollars; high enough to make me forget it./w3tcompact/icons/smile.gif
Bird
/ Metal Post Driver #11
I think every hardware store in this part of the country sells "t-post drivers" for under $20. Just a piece of pipe about 2' long with a steel plate welded on the top end, and a lot of weight in the top end, and a handle welded on either side so you slide it down over the top of the post and then start hammering up and down with it. When the ground's soft and wet, they go in real easy, and when the weather's hot, and this black clay's hard and dry, you're lucky to get 2 or 3 posts in the ground before you have heat stroke./w3tcompact/icons/frown.gif And I've had all the experience I ever want with one of those contraptions, too.
Bird
/ Metal Post Driver #12
Hi Wen yep they sound like the same thing we have here . this driver is hyr( the smaller one's are pto driven)with a tall mast for driving deer posts (deer farms and cattle yards) in hard ground some contractors use a spike(pionted truck axle )frist then chain it to the hammer to pull it back out then drive there post
cya
JD Kid
/ Metal Post Driver #13
Wow, JD, sounds like you must have some ground as hard as this central Texas dirt!
Bird
/ Metal Post Driver #14
hi Bird
yep alot of ground has a iron or clay pan under ground .all posts are pointed but in hard ground try driving a 6 inch post a straner is even harder 8-10 inch but if the grounds that hard ya back to hand digging or blasting in rock
ps wen i'll try and find a pic on the net of our post drivers just to see they are like the one you are talking about .most contractors here use side shift so it drives behind the right hand wheel(saves backin up all the time)
cya
JD Kid
/ Metal Post Driver #15
hi wen i found the kind alot of the contractors here use
http://www.kinghitter.com/
there is heaps of tricks to useing them too one good one is to turn the DROP lever upside down so ya don't grab it when shifting the angles the other thing is to get into tha habbit of holding posts by the side not the top (i have a mate who used to fence but can only count to 5 now!!!!)
cya JD Kid
/ Metal Post Driver
Bird, I have a T Post driver. That is why I want one that the tractor drives. People that have used those much, can't hear, but have big arms and mushy brains. /w3tcompact/icons/smile.gif
/ Metal Post Driver
jkid,
Thanks, yes that sounds like how it is done. Since they seem to be priced so high, I may have to make that a project to build one.
1042 (A60430)
1042 (A60430)
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Grease Pneumatic Air Gun, 50' Hose  (A62679)
Grease Pneumatic...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
360 Y-Drops (A65640)
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
