Oil & Fuel Metal on oil drain plug magnet
   / Metal on oil drain plug magnet #1
Mike in La.
Sulphur,La./Rusk,Texas
6500 4x4 FEL
Just did the first 50 hour oil change on my 6500fwd and found the magnet on the plug had captured a good deal of metal. The material was the consistency of talcum powder and the magnet itself and the recesses around it were completely covered with it. I'd estimate it to be about a half teaspoon in volume. I suspect it is residue from machining and casting but would be interested in knowing if anyone else has noticed this during oil changes.
   / Metal on oil drain plug magnet #2
Yea Mike you aren't the only one. I saw the same thing. THis was at the 50 hr service at all three drain plugs. 1--engine oil 2&3---hyd/trany sump. Have you cleand the Hyd sump screen too?
   / Metal on oil drain plug magnet #3
I would consider it completely normal. If there were large chunks of metal........ that might be a problem.
   / Metal on oil drain plug magnet #4
This is exactly why you have a 50 hour major service, to hopefully clear all the nasties from manufacturing. I've seen questions here before asking if it is really necessary to change all those large quantities of oils and filters so quickly on a new tractor - this would seem to confirm that necessity.
   / Metal on oil drain plug magnet #5
I serviced a kubota for a friend last year and it had the same thing after 45 hrs of breakin period.
Its normal during the first oil change to see the metal dust particles.
2010 Chevy Silverado HD Crew Cab (A52384)
2010 Chevy...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
