Metal Cutting Bandsaw Blades
   / Metal Cutting Bandsaw Blades #1
workinprogress
Vermont
Cub Cadet 1512
Hello All,
I was lucky over the holiday and was given a metal cutting bandsaw (basic Tractor suppy 4 1/2 inch Horizontal/Vertical). The saw came with a very basic (cheap) blade and I wanted to purchase a couple to have on hand. I looked around locally for some but didn't find much. The saw uses a 64" blade. Does anyone have a suggestion on type of blade (variable tooth vs standard tooth), brands, etc?
Thanks,
   / Metal Cutting Bandsaw Blades #2
Variable pitch blades 4-6 or 6-8 are what i use Timber wolf silicon blades
are very good. Good luck
   / Metal Cutting Bandsaw Blades #3
I use the variable tooth Starret blades in my saw...I but them from Enco.
   / Metal Cutting Bandsaw Blades #4
For what it's worth.... on my old Harbor Freight saw similar to yours, I used their blades Item#42374-3VGA 18 teeth per inch, and had VERY good results and fairly long life out of em. Plus they were cheap too;)
   / Metal Cutting Bandsaw Blades #5
I have had good luck with Morse Bi-Metal blades. Seemed to last longer than others that I have tried.
   / Metal Cutting Bandsaw Blades #6
I've been using the 64 1/2 inch Portland Model Number 42374 blade from HF on my HF bandsaw and getting good results.
Cut every piece of steel on my recent welding table project from the same blade, and it's still going strong...
   / Metal Cutting Bandsaw Blades #7
I use Morse blades 18tpi and get them from McMaster Carr.
Bill
   / Metal Cutting Bandsaw Blades #8
I use a Fastenal variable 14-18 TPI Bi Metal cuts straight & fast.
   / Metal Cutting Bandsaw Blades #10
I've used a variety of blades in bandsaws, and I found that going easy on the feed and heavy on the coolant was more important than the brand.
If it's a horizontal saw, you don't need to baby sit it, so unless it's in a production setting, who cares if you let it feed on the slow side? Fire and forget....you can do something else while it cuts.
2025 CFG Industrial M-AG (A50123)
2025 CFG...
Concrete Mixer Mini Skid Steer Attachment (A51691)
Concrete Mixer...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
2019 Freightliner M2 106 Truck Recycling Truck (A51692)
2019 Freightliner...
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
