Metal building house plans ?
   / Metal building house plans ? #1
gmccall
Forney Texas
kubota
Do you have to have an Architect's plans to build with ?
I plan to build a metal building to match a floor plan I found on the internet.
Can a good carpenter use the floor plan that has room size general dimensions and build the house ?
   / Metal building house plans ? #2
No, you don't need an architect.
Are you having a building shell erected by a company and then hiring someone to finish it out?
An all-round, experienced carpenter can do a good job if given enough time. You do need to have detailed plans though so that plumbing and vents are installed correctly. I like good drawings. Also, companies like Winslows will build a structure to your custom specs for no extra charge. My shop has a full bathroom, a shower for the horses, and an upstairs large, air-conditioned, office/electronics lab.
   / Metal building house plans ? #3
If you are outside city limits in TX, then there are no permits and you can do what you want. A half decent builder could frame out your floor plan if you drew it on a napkin with a crayon. If he is good, he will go over your plan with you, make suggestions and fine tune it.
Eddie
   / Metal building house plans ? #4
It's easier (and cheaper) to erase a line on a piece of paper than it is to tear down a wall or move a door. Besides, what does the carpenter bid on?
Thanks for the replies,
I would like to have a metal building built to the footprint of a floor plan.
Then have a carpenter construct the interior from a floor plan.
However, I am beginning to think, that I may miss something trying to allow for plumbing and electrical with receptacles and switch plates, etc.
Cost would have to be an estimate ....
I am being told construction costs for building only is about $100 a sq.ft. in our area of Texas,
with nice finish out inside.
May purchase the plan, so I don't cause a problem, since
   / Metal building house plans ? #6
Actually, my son just got a $95 sq. ft. quote from a builder to do a 3000 sq ft home on 2 acres in Sunnyvale City limits. This would be a standard, 2 story, 90% brick home with 2 fireplaces. So I think $100 sq ft for metal shell and inside finish out is way high.
Thanks for the info Fawken.
The Quote I mentioned was for a slightly modified and modular 864 Ulrich cabin with 8" front porch. The quote was $114,000 (16x54') for the cabin plus $8700 for the concrete foundation. The price included bringing the Unit out to my land and set up. The unit is supposed to be built to Stick house standards. I own the land. I know there is a lot of factors here, but their price sounded way to high to me.
I need your son's builder to come to my land in Whitney. lol
   / Metal building house plans ? #8
I'm going to send you a mail message with his number. His name is Jason and he lives right off of 548 in the new edition just South of Equestrian Estates. He builds mostly in Highland Park and Frisco, but has built several homes in Rockwall as well.
Thanks Fawken
The small square footage unit I would like to have built is not likely to worthy of your builders time, but it may not hurt to ask.
Fawken,
I forgot to ask you, does the $95 sq. ft. cost include the lot also ? Is that a "turn key price" for the most part ?
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2017 FREIGHTLINER...
UNUSED Woven Landscape Fabric (A53117)
UNUSED Woven...
American G-Model Pump Jack (A55218)
American G-Model...
UNUSED RAYTREE RMT48 HYD TRENCHER (A54757)
UNUSED RAYTREE...
