radioman
Super Member
I think the OP is not getting full instructions or understand the concept how to resolve it. The problem can be resolved in one of either 2 ways. airflow or insulate correctly.
To have proper airflow, you need air inside the building to be nearly the same as outside. The proper way of doing it is to have outside air come in from bottom of building and flow out at top. This uses the sun convection air flow and pushes moisture upwards to either roof vent or gable. make sure its either roof vent or gable- not both or you will stop proper airflow.
The other way is to remove the foil insulation and have foam spray on the metal. Its the same concept as your foam coffee cup never condenses from hot or cold liquids. The problem with this is you need to have drywall or wall covering like plywood/osb to prevent fires from sparks.
If the OP is getting so much water dripping, I would verify the ridge vent is not blocked and leave the door open 24/7 until he can get 2-4 vents installed on both sides of bldg along the floor. problem is will the OP be needing to heat the bldg? then this will not work.
On a side note, if Op has water issues now with foil insulation, it may be no good now since its soaked and can mold.
