Metal Building, Concrete Question
/ Metal Building, Concrete Question #1
loudhornsrule
Bronze Member
Hello folks. My plans are to build a 30x30 detached garage on concrete. I was told I could do it 2 ways. Either put my poles in the ground and pour concrete around it or put weld plates in the top of concrete and weld my poles to it. Which would be better, and why? I already know which is easiest. In North Texas. Thanks in advance
/ Metal Building, Concrete Question #2
I'd go weld plates set in the concrete. Easier to get the correct elevation, less digging, easier to repair should one somehow get busted. Poles in the ground rot and then what do you do. Just my two cents worth.................Mike
/ Metal Building, Concrete Question #3
Do the one you find easiest. I have poles set in holes with concrete placed after building was complete
/ Metal Building, Concrete Question #4
My 24 x 42 ft metal shop building is attached to the concrete pad via anchor bolts cat were cast into the concrete when it was poured. Another way is to attach with expansion-type anchor bolts via holes drilled into the concrete. My 24 x 36 ft carport is done this way.
Good luck
/ Metal Building, Concrete Question #5
Is this a metal building,pole barn type,stick built ? How big are the poles you want to use ? Wood or metal poles ? Always try to avoid setting poles in the ground then filling with concrete...to much chance of wood rotting or metal pipe rusting. If you go with the welded plates make sure you have deeper concrete where the poles will set.
Metal building with square tubing uprights. 3x3x1/4 Thanks Folks
/ Metal Building, Concrete Question #7
Within the first year of having my pole barn I hit the outside corner with my forks, dropped a wood stove off a pallet into the wall, hit the garage door rail with my bucket and the bottom of the garage door with my canopy. Put the poles on top the concrete.
/ Metal Building, Concrete Question #9
Suggestion....if the tubes are 3x3 then find some tubes that are bigger where the 3x3 will fit inside the bigger tube. Make the bigger tubes say 12 inches long and weld each one to a metal plate and then set them in the wet concrete. When the concrete has set up then insert the 3x3s in each weld plate assembly. Bolt the 3x3 to the bigger tube so then if you damage the 3x3 tube just unbolt it and insert a new tube.
/ Metal Building, Concrete Question #11
Plates bolted to the concrete. Never seen any other solution except variations on how they are bolted. Most foundation designs I have seen have a reinforcing ring around the perimeter with cross tie grade beams at each bay line.
Ron
/ Metal Building, Concrete Question #12
About 25 years ago I used to put up sheds for a living- from 2-car garages up to large sawmills & farm sheds, largest we did was 154' clear span. There are certainly more than two ways that you can do the bases but I would not do either of the methods you have mentioned. As others have mentioned, poles set in the concrete will rust around the bottom- I have this problem at my property with a lean-to wood shed the previous owner put on the back of my main shed. Here's how I would do it;
Make your columns (poles, uprights, whatever you like to call them) with a square plate welded to the bottom with four holes at the corners. Using one of the baseplates as a template, weld up a cage for each footing that will have four threaded rods sticking up out of the concrete. For your size building, some 9/16" all-thread would be plenty strong, drill your base plates 5/8" so they slip over the threads easily. The welded cages serve two purposes- they hold the threaded rods at the right spacing, plus they set in the concrete so that you don't just have straight rods that will pull out.
After digging your foundation holes, set up a pair of hurdles at each hole and suspend your foundation cages in the holes by their nuts, set them up perfectly straight, square and level. (we used to have fabricated jigs to adjust and hold everything in position, but you could suspend a plank with four holes across the hurdles to hang your cages). Grease the threads so the concrete won't stick to them.
Pour your concrete around them and trowel off to form a nice flat pad. It is not critical to get the top of the concrete footings perfectly level at this stage but getting it as close as you can will save work later.
Make up some sheet-metal (I'd use 2mm thick, don't know what the imperial equivalent is) plates about 2" square with a 'dot' in the centre, the 'dot' is just a small round piece of metal about 1/2" thick- something like a 3/8 hex nut would work, or ask your steel supplier for some slugs from their hole punch, about 1/2" thick by 1/2 to 3/4' diameter, whatever holes they have been punching out. Tack weld the dot in the centre of your 2" squares- one for each column.
Once the concrete has set, place one of your 2" squares, with the dot up, in the center of each pad, then go around with a laser level or dumpy level and get them exactly level. Use sheet metal shims under the dot plates to bring them all up to exactly level with whichever one starts off the highest.
You can now place your columns over the threaded rods, the base plate will pivot on the 'dot' and you use the base nuts to adjust the column to vertical. After your frame is complete, grout under the plates with a slurry of cement.
This may sound like a lot of effort but if you use this method and get everything square, straight and level (I used to work to less than a millimeter tolerance in 3 dimensions, even with a shed 100' x 150') and work to similar tolerances with making your frame members, the shed will practically build itself from that point on.
As mentioned, I have used this method for foundations for buildings from double carports up to sheds you can drive a semi-trailer in circles inside. It will enable you to stand your columns up and assemble the rest of the frame with ease.
Ford 8210 (A60462)
Ford 8210 (A60462)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2018 Nissan Sentra Sedan (A59231)
2018 Nissan Sentra...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
