Metal bonded seals for banjo type hydraulic hose fittings
   / Metal bonded seals for banjo type hydraulic hose fittings #1
Lodi
walworth WI.
Lu Zhong
Hello and good day.
I have a Lu Zhong 254 with an unknown brand FEL.
All the hydraulic fittings on the FEL use a metal bonded seal
on the banjo type fittings and everywhere else.
The Lai Dong engine oil pan even uses this type of seal on the drain plug.
I cannot find these seals anywhere.
Can anyone help?
   / Metal bonded seals for banjo type hydraulic hose fittings #2
I have some in stock
Do you know the ID x OD approx. sizes..??
   / Metal bonded seals for banjo type hydraulic hose fittings #3
G'day they are also known as dowty washers if that helps
Jon
I measured with a caliper and got these numbers....
Small ring: OD = 19.7 mm. ID = 13.7 mm.
Large ring: OD = 30.4 mm ID = 21 mm.
I will try to attach photo.
My hydraulic fittings are all metric sizes.
Can't find them anywhere around here.
   / Metal bonded seals for banjo type hydraulic hose fittings #5
Hello and good day.
Can anyone help?
Did you try a local hydraulic supplier? The dowty washers are used with BSP ports. When I added an oil gauge to my Kubota, a local hydraulic fitter had the necessary BSP fittings/adapters to convert to 1/8" NPT for the gauge.
Yes have tried all local farm equipment suppliers. (There are many here)
I actually found a hose and fitting repair shop that was able to make me a new hose
cutting the ends from my broken hose and brazing them on to new crimp fittings.
Amazing job they did!
They had never seen the metric fittings from my tractor anywhere before.
   / Metal bonded seals for banjo type hydraulic hose fittings #7
Farm equipment suppliers typically have US-style fittings, as most of the big iron farm tractors are US. A hydraulic/hose supplier has the fancy fittings for all hydraulic needs. That's why I specifically said hydraulic supplier :)
Glad it works out though... hope the brazing holds!
   / Metal bonded seals for banjo type hydraulic hose fittings #8
You could probably substitute a copper washer in its place.
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
2022 Caterpillar 310 Midi Excavator (A51691)
2022 Caterpillar...
2003 Evan's Log Trailer, Super Singles (A52384)
2003 Evan's Log...
American G-Model Pump Jack (A53472)
American G-Model...
RYOBI 40V BRUSHLESS ELECTRIC 20" PUSH MOWER (A51248)
RYOBI 40V...
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
