Melting lead for weights
   / Melting lead for weights #1
Bill_C
Gallatin TN
Ford 1100
I've got several useless car batteries lying around, I'm thinking about cutting them open and melting the lead down to make wheel weights...Anybody here done this? I had in mind making an outdoor fire pit and using charcoal, and melting the lead in a ceramic pot. Using appropriate safety gear of course.
   / Melting lead for weights #2
Don't do it! I've tried it and the amount of lead you'll end up with is negligible at best. I keep the little pattie of lead as a reminder not to do that again!!!!
The acid gets everywhere despite your best efforts and the combination of sulfuric acid and lead vapors can make you very sick (or dead). Better source of lead is wheel weights. You can get them at tire stores.
Best of luck.
Mark
   / Melting lead for weights #3
If you want lead go to a local shooting range and start digging. That is if no one is shooting.:D :D :D
Best of luck.
Mark
Thanks for the response...but I figure I've got over 150 lbs of batteries, and most of that weight is lead....sure wouldn't call that negligible! And it'd be awfully tough to come up with 150 lbs of wheel weights from tire stores...or the gun range...
I was going to rinse the batteries out as I cut them, then I could passivate the lead with baking soda before melting.
However, I've worked in a copper electrorefining plant, which used large football-field size vats of acid to refine copper, so I'm not inexperienced when it comes to the hazards of hot acid.
   / Melting lead for weights #5
Hey, you know more about it than most of us. Go for it!!:D :D
   / Melting lead for weights #6
We had a guy that picked up batteries and over 15 years he aged about 40 years and was walking on crutches. I wouldn't mess with the stuff. Of course your experience may vary.:D
   / Melting lead for weights #7
Bill what are you doing with the acid??...It is a HAZMAT material...which means you must control it from entering the environment...
   / Melting lead for weights #8
And so is I would imagine, the rinse water.....
   / Melting lead for weights #9
One of my neighbors dug a hole and was burying batteries along with the rest of the stuff he wanted to get rid of. I offered to take them away and bring him the core charge just to keep them out of the ground. Wouldn't budge on it, so they probably got buried, which is a shame.
Control of hazmat chemicals is up to the people who handle it, and batteries are one of them. Lead is also another one along with the fumes being lifted into the air as it is heated. I worked around molten lead, sulfuric acid, nitrate acid, hydracloric acid, molten zinc for 15 years and one of the things I did learn was to respect it. The property that the plant was on finally sold after being vacant for 15 years due to the contaminants in the soil and the last owner took a beating on the price. Those contaminants were the same as the batteries your talking about, so consider the effects of saving pennies at what cost?
David from jax
   / Melting lead for weights #10
Scrap yard sells lead for about 30 cents per pound.
2023 UNVERFERTH 632 LOT NUMBER 179 (A53084)
2023 UNVERFERTH...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
(2) Sumitomo 11.00 R22 Tires (A51573)
(2) Sumitomo 11.00...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53472)
2018 John Deere...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
