Melroe M600 Hydraulics jumpy and weak
   / Melroe M600 Hydraulics jumpy and weak #1
sleazydan
I just bought this old machine and started using it more and more. The whole time I have been using it though the lift and articulating actions seem to be really jump not to mention weaker than expected. The pump has a recent rebuild and is full of oil. The man I bought it from said it was probably air in the lines, is this legit and if so how do I bleed them? Other than air in the lines any suggestions that would fix my problems? What can I expect to be able to lift with this machine?
   / Melroe M600 Hydraulics jumpy and weak #2
I have a 600 bobcat and had the pump and lines off. The unit is self bleeding and as long as the reservoir is vented there should not be a problem with that. I would have the cessna pump checked out. Mine will lift a thousand pounds quite easily. After this it tends to get very lite on the rear wheels even with the counterweight.
   / Melroe M600 Hydraulics jumpy and weak #3
sorry i am new but i have question about where hydro oil goes in. on our m600 there is one place where it says fill here with transmission fluid. is that the same
thank you bos
   / Melroe M600 Hydraulics jumpy and weak #4
The chain cases are also the hydraulic reservoir. There is a cross feed tube that keeps fluid level for both sides, and 1 fill point. Recommended to use Dexron transmission fluid, using normal hydraulic fluid will cause drive clutch slippage and wear.
2016 CHEVROLET SILVERADO 3500 DUALLY (A53843)
2016 CHEVROLET...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
1996 INTERNATIONAL 4700 4X2 DUMP TRUCK (A51406)
1996 INTERNATIONAL...
New Holland C185 (A47477)
New Holland C185...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
