Melroe M600 Hydraulics jumpy and weak
   / Melroe M600 Hydraulics jumpy and weak #1
sleazydan
I just bought this old machine and started using it more and more. The whole time I have been using it though the lift and articulating actions seem to be really jump not to mention weaker than expected. The pump has a recent rebuild and is full of oil. The man I bought it from said it was probably air in the lines, is this legit and if so how do I bleed them? Other than air in the lines any suggestions that would fix my problems? What can I expect to be able to lift with this machine?
   / Melroe M600 Hydraulics jumpy and weak #2
I have a 600 bobcat and had the pump and lines off. The unit is self bleeding and as long as the reservoir is vented there should not be a problem with that. I would have the cessna pump checked out. Mine will lift a thousand pounds quite easily. After this it tends to get very lite on the rear wheels even with the counterweight.
   / Melroe M600 Hydraulics jumpy and weak #3
sorry i am new but i have question about where hydro oil goes in. on our m600 there is one place where it says fill here with transmission fluid. is that the same
thank you bos
   / Melroe M600 Hydraulics jumpy and weak #4
The chain cases are also the hydraulic reservoir. There is a cross feed tube that keeps fluid level for both sides, and 1 fill point. Recommended to use Dexron transmission fluid, using normal hydraulic fluid will cause drive clutch slippage and wear.
2015 ISUZU NPR 16FT BOX TRUCK (A54313)
2015 ISUZU NPR...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
Adams 5 ton Fertilizer Buggy / Wagon (A53473)
Adams 5 ton...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2018 TROXELL 150BBL ALUMINUM TANKER (A53843)
2018 TROXELL...
