Mechron 2240 overheating - fan won't turn on
   / Mechron 2240 overheating - fan won't turn on #1
CircleFrameHill
Kioti Mechrom 2240
Our Mechron 2240 overheats. The electric fan is not turning on, but will spin when hooked directly up to 12v power. Fuse appears good and I swapped it with another. Coolant is full and I've tried purging any air from the system.
Other ideas? Is there a different temperature sensor to kick on the fan, other than what would show on the dash (which shows hot)?
   / Mechron 2240 overheating - fan won't turn on #2
did you check the relay? doubht its direct wired. then I would check to see if the computer/sensor is commanding it on at the relay.
Do you know where the relays are and which one would be for the fan motor?
   / Mechron 2240 overheating - fan won't turn on #4
No idea
   / Mechron 2240 overheating - fan won't turn on #5
Temperature sending unit or the coolant fan relay. Any mechanic will quickly puzzle this issue out.
NANCE UNDERGROUND CONDUIT BOX (A50854)
NANCE UNDERGROUND...
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A51039)
2019 Ford F550 4x4...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
New/Unused 20ft Farm Metal Driveway Gate (A48837)
New/Unused 20ft...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
