Mechron 2240 overheating - fan won't turn on
   / Mechron 2240 overheating - fan won't turn on #1
CircleFrameHill
Kioti Mechrom 2240
Our Mechron 2240 overheats. The electric fan is not turning on, but will spin when hooked directly up to 12v power. Fuse appears good and I swapped it with another. Coolant is full and I've tried purging any air from the system.
Other ideas? Is there a different temperature sensor to kick on the fan, other than what would show on the dash (which shows hot)?
   / Mechron 2240 overheating - fan won't turn on #2
did you check the relay? doubht its direct wired. then I would check to see if the computer/sensor is commanding it on at the relay.
Do you know where the relays are and which one would be for the fan motor?
   / Mechron 2240 overheating - fan won't turn on #4
No idea
   / Mechron 2240 overheating - fan won't turn on #5
Temperature sending unit or the coolant fan relay. Any mechanic will quickly puzzle this issue out.
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
DIFFERENTIAL ASSEMBLY (A55745)
DIFFERENTIAL...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
JCB 2145 (A47477)
JCB 2145 (A47477)
LINCOLN WELDER (A55745)
LINCOLN WELDER...
