Mechanical tubing & pins source?
   / Mechanical tubing & pins source? #11
I have gotten stuff from ASAP Source and was not pleased with the extra $5 handling added to EVERY order, over and above the cost of the material and shipping. In my opinion it makes them non-competitive.
   / Mechanical tubing & pins source? #12
Hi
A friend of mine built a cadplans digger. He used the mech tubing they supplied. I also have seen it at onlinemetals. It was not possible to find locally for us. It seems to be a specialty item. I suspect that the mechanical tubing has a rated strength specification, as opposed to something close, such as sch80 pipe and the like.
Good luck with your project.
John
I appreciate all the ideas! Thanks! /forums/images/graemlins/smile.gif
Thinking about it, I bet KK uses schedule 80 pipe, rather than mechanical tubing. Seems like there is more play between the fork axle and the tubing than would be there if the rather close tolerance mechanical tubing and matched pin stock were used...???
Anyway, if I can find a piece of 1" ID schedule 80 pipe, I will see how it compares to what KK uses, and move on from there... /forums/images/graemlins/smile.gif
   / Mechanical tubing & pins source? #14
Mad
You are right ! I had frogotten about that charge. Haven't done any machine work recently.
Vernon
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59575)
2018 FREIGHTLINER...
208320 (A58375)
208320 (A58375)
2017 John Deere 1025R Tractor - 626 Engine Hours (A56436)
2017 John Deere...
FORKLIFT (A56857)
FORKLIFT (A56857)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
