Backhoe Mechanical or Hydraulic thumb?
   / Mechanical or Hydraulic thumb? #31
It worked. Went to the local industrial supply to get the fittings to match, and connected return to other port.
It picked up a couple hundred pound rock. I gingerly pushed the thumb with the bucket curl, and that worked too. That's less than a full test, but confirms the principle.
Now I'll go back and get a relief line tapped into the supply, with overflow to the return.
   / Mechanical or Hydraulic thumb? #32
The relief valve went in with not much fuss, a couple hundred bucks all told, and the thumb is in unrestricted use. Someday I'll use one on another tractor to see if mine is different.
The relief valve comes set to 2500#, less than the bucket curl supposedly. In practice, I set either the bucket or the thumb, squeeze with the other, and off we go. Articulation with a load requires moving (operating) both at once, which I'll get better at.
Thanks again to all who coached me on this -- a good experience and a happy outcome.
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
2015 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A56858)
2015 Chevrolet...
