Mechanical HELP!
/ Mechanical HELP! #1
Mobass
Lebanon, MO
Mahindra 8560
I have a 8560. The problem I am having is it will run then all of sudden shut off like some one turned the key off. The dealer came and picked it up and when it got to there shop it ran fine. $350 dollar bill for all that. They bring it back it starts they back it off the trailer I move it to the garage, turn it off put side cover back on, start it when to back up moved a inch and just dies. Call the dealer they said they would have the mechanic come out and look at it the next morning. Next morning comes, wait around 2 hours no mechanic. I try and start it, fires up I use it for 2 hours and no problem. The dealer sends out a guy to pick tractor up not a mechanic :banghead: GRRR. So this morning I am moving hay out of my lower field and it quits again. The dealer first time had me spray starting fluid in the air intake it would start but would not continue running. I think there is a electrical issue that is keeping the fuel pump from working. any ideals??? Oh I forgot they first had me change the fuel filters saying they were probably plugged up. the filters looked like new but I still replaced them.
/ Mechanical HELP!
fuel shut-off solenoid...check the wire connector plug first
I believe you are right. Went out this morning and it fired up. So I will replace the solenoid.
:confused3:
/ Mechanical HELP! #5
:confused3:
You should 1st make sure the connector contact to the solenoid is clean and tight, as advised. Solenoids are seldom intermittent.
