Mechanical Fuel Injectors
   / Mechanical Fuel Injectors #1
dpauly
Bronze Member
Hertford Cty, NC
Branson 3120R
Greetings, all. Putting this in the TYM slot because of them now owning Branson and I believe they still use Kukje engines with mechanical injectors. Question: is there or is there not a "cup" at the "head" end of an injector (in my case a A1700; 2011 vintage engine) that can/should be pried out when removing/replacing injectors? I've seen pictorials that seem to indicate this is the case; while I've also seen them that only depict the copper washer at the end of the injector. My intuition (I'm not well versed in the diesel world, btw) tells me there almost has to be a cup but again, despite having a service manual (that someone seems to have put together using copies of various parts of the real one . . .) I just don't know and I don't want to screw anything up by trying to pry out something that wasn't meant to be pried out. By the way, does anyone know the difference between a Kukje A1700N2 and A1700N3 engines? Thanks in advance.
   / Mechanical Fuel Injectors #2
Looking at the TYM site, the difference between those engines, N2 vs N3 is likely just the tuning for HP. The 3515 has an N2, the 3015 has a N3, the 2515 has an N6. N=Naturally Aspirated.
Mine is a T2300T2. T for Turbo.
You will need someone better than me to explain injection parts. Asteral knows that equipment well (iirc, he worked on them for a Branson dealer).
Thank you, Torvy. Asteral Is a fountain of knowledge for sure. In another post I explained that I actually found a sticker on my engine partially obscured by the exhaust manifold that says my engine is actually a A1500N2 and not an A1700 of either type and even though another source (a Kukje related site, I believe it was) stated A1500's weren't introduced until 2018 his records indicate they actually were available and used in some Branson's from 2010 - 2012!
2011 BMW 528i Sedan (A46684)
2011 BMW 528i...
2019 Chevrolet Tahoe SUV (A46684)
2019 Chevrolet...
48 FT Trailer (A46683)
2012 Ford Escape SUV (A46684)
2012 Ford Escape...
2012 Ford E-350 Cargo Van (A46683)
2012 Ford E-350...
2017 Ford F-350 4x4 XL Crew Cab Pickup Truck (A46684)
2017 Ford F-350...
