Meandering Diesel question.....
   / Meandering Diesel question..... #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Let me preface that this is merely a question from being curious, I'm certainly not going to try this (and don't expect I could if I WANTED to try it)
Ok, our machines usually run on diesel.
My understanding is a jet engine runs on a refined version of diesel as they are also compression ignition engines.
My question is.... if you put jet fuel (full tank) into a tractor or backhoe, how would the machine operate?
Would it be akin to putting high octane into a gas engine and give some better pulling power?
Ok, so it's slow and I'm bored.
   / Meandering Diesel question..... #2
Jet fuel Jet A is more highly refined to ensure there is no water which could freeze or waxes that could gell at high altitudes. The fuel also has less lubricity so it could damage the injection pump if used long term in a diesel.
   / Meandering Diesel question..... #3
This was tryed here. The results were fuel-injector pumps siezing and injectors problems? whether it takes more than a tank, who knows..Some of it started in 4 hours running? The tolerences must be built for jet-A?
   / Meandering Diesel question..... #4
You'll fly of course!
Years ago we ran Jet A in pickups and dumps that we plowed a local airport with. All of those trucks (still have two) ran fine on it and continued to run fine. However that was ~ 20 years ago in trucks that are now 30 and 40 years old. With USLD, and high pressure injection systems, I think I'd pass now.
   / Meandering Diesel question..... #6
Diesel -> Kerosene -> JP-8
All off the same cut of crude.
Sort of like:
Gasoline -> Liquid based solvents
Could you... yes. Safely? Especially in newer engines? Questionable. If you did, it would probably be safe to add some oil to it. Ala directions for the old Continental multi-fuel engines. Designed to run on diesel - but could run on about anything - just add oil. There's a little plaque on the tank for directions per-fuel type, of how much motor oil to add in. The only thing it said it not to run was Aviation level gasoline - 102+ Octane / Race fuel. Probably because it would cause a run on.
   / Meandering Diesel question..... #7
i think it has more to do with what has been added or removed from the fuel, and probably most notably sulphur in diesel fuels. i haven't a clue about everything they do when refining, and i suspect that no matter what some people here claim to know about fuels, there isn't anyone who knows everything that each company and refinery add or remove before it gets to the pumps.
also, as to whether using "high test" unleaded will do anything to directly improve performance is another purely subjective discussion that has been hashed a bunch of times.
   / Meandering Diesel question..... #8
In diesel fuel, it's all about what's removed - mainly, the sulfur.
How much sulfur removed is directly connected to how well the hydro cracker in the refinery is working and what type of crude is being used.
Heavy/Sour crude from Canada, certain regions of the US and Venezuela have to spend a long time being refined then hydro cracked, which means it will have little to no sulfur in it.
Light/Sweet crude can be passed through the refineries in a rather quick amount of time, which means less time being spent hydro cracked, which in turn leads to a bit higher sulfur content - typically 7+ Ppm, allowing for sulfur to be collected while being pipe lined.
Refineries and terminals do not add anything in - they just refine it and sell it - or pipeline it and sell it. (Although, sulfur can be picked up via a pipeline, naturally from the steel.)
It's up to the each, individual reseller to put the additives in it - even if it is a 'brand' all the additives are stored separately and loaded into the delivery truck when the truck is filled.
In my opinion? Don't buy unleaded and don't buy premium.
With EPA Mandated 10% ethanol blend, upwards of 15% - gasoline today is junk. There is no need for super high octane either.
   / Meandering Diesel question..... #9
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
Croft 5,000lb Vehicle Tow Dolly (A52377)
Croft 5,000lb...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
2016 Chevrolet Sonic LS Hatchback (A53424)
2016 Chevrolet...
