Md 1600 hydraulic oil in crankcase
   / Md 1600 hydraulic oil in crankcase #1
Ric27
yanmar
crankcase full of hydraulic oil. bad squealing sound. I don't know where to start looking for cause.
   / Md 1600 hydraulic oil in crankcase #2
I'd start by considering the shaft seal on my hydraulic pump. You may be able to just replace the seal, have the pump rebuilt by a hydraulic shop, or replace the pump. That should take care of the hydraulic oil in the crankcase. I don't know about the squeal unless the pump is complaining.
   / Md 1600 hydraulic oil in crankcase #3
Is your machine a Mitsubishi MD1600 ??? This is the Yanmar section.
   / Md 1600 hydraulic oil in crankcase #4
Just replacing the seal will not fix the problem. The internal seals are bad. It is not a repairable pump. If you supply the numbers off of the end of the pump, i can probably supply you with a new or used pump.
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
City of Buckhannon - 2014 Ford Fusion SE (A52384)
City of Buckhannon...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
MacDon C3012F Corn Head (A53342)
MacDon C3012F Corn...
John Deere 2155 Tractor (A51573)
John Deere 2155...
