Md 1600 hydraulic oil in crankcase
   / Md 1600 hydraulic oil in crankcase #1
Ric27
yanmar
crankcase full of hydraulic oil. bad squealing sound. I don't know where to start looking for cause.
   / Md 1600 hydraulic oil in crankcase #2
I'd start by considering the shaft seal on my hydraulic pump. You may be able to just replace the seal, have the pump rebuilt by a hydraulic shop, or replace the pump. That should take care of the hydraulic oil in the crankcase. I don't know about the squeal unless the pump is complaining.
   / Md 1600 hydraulic oil in crankcase #3
Is your machine a Mitsubishi MD1600 ??? This is the Yanmar section.
   / Md 1600 hydraulic oil in crankcase #4
Just replacing the seal will not fix the problem. The internal seals are bad. It is not a repairable pump. If you supply the numbers off of the end of the pump, i can probably supply you with a new or used pump.
John Deere 5055E (A53317)
John Deere 5055E...
Year: 2005 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2005 Make...
We Don't Dial 911 Wall Art (A55853)
We Don't Dial 911...
JCB 2145 (A47477)
JCB 2145 (A47477)
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
3ft Metal 5-Point Star (A55853)
3ft Metal 5-Point...
