McCormick 3 PT stuck
   / McCormick 3 PT stuck #1
kl9
La Crosse, WI
Deere
Pretty straightforward. I don't know a lot about tractors, but the 3 pt is stuck in the highest position (with an attachment on it so it isn't a weight issue). I believe there is plenty fluid in it. Any suggestions? Someone told me to change the hydraulic filter first. I hope it isn't the hydraulic pump.
   / McCormick 3 PT stuck #2
Uncertain about your McCormick but most 3 points are gravity down, power up. I did say most, but not all. Most of ours do not even require the engine to be running to drop the 3 point. Two of ours, however, have electronic 3 point and need to have at least electric power to the control in order to drop, but at that point those 2 drop under gravity, not hydraulic power. Is yours electronic control or does it have a mechanical linkage to the control valve?
Good question. I'm not sure as I'm going to be borrowing the tractor from a friend. I could look more into that. If it isn't going down on its own I might be missing something from an electronics perspective?
   / McCormick 3 PT stuck #4
Possible the needle valve to control the drop rate is screwed all the way in?
   / McCormick 3 PT stuck #5
Any idea of the model number?
   / McCormick 3 PT stuck #7
It appears the X10.50H is a Kioti DK500se in red. Maybe those guys can help.
Guys?
I figured it out. It was the needle valve being screwed all the way in.
   / McCormick 3 PT stuck #9
Thanks for the update, easy fix!
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A51691)
2022 McConnel...
2017 Case IH Magnum 380 ROWTRAC CVT Tractor (A53342)
2017 Case IH...
2021 FORD TRANSIT 250 CARGO VAN (A52576)
2021 FORD TRANSIT...
2012 Ford F-250 Pickup Truck (A51692)
2012 Ford F-250...
2025 Western Star Trucks 49X Dump Truck, VIN # 5KKHBWDR5SLVH9247 (A51572)
2025 Western Star...
72In FEL HD Round Back Bucket (A53472)
72In FEL HD Round...
