maybey a dead cell in the battery???
   / maybey a dead cell in the battery??? #1
TOMMYHPX4X4
schriever, louisiana terrebonne parrish
gator hpx 4x4
i have a 08 700 rhino now there is no telling how long the battery was on the shelf before they put it into my rhino but here is my problem when i used to ride the volt meter was always reading 14 volts or over but today i went to pull my next door neighbor's forklift off a trailer and the battery was dead well i jumped it off but afetr riding it around all day i haven't been able to get it to read 14 volts it will go to 14 every so oflten but it mainly stays at 13.9 0r 13.6 could this be a dead cell?? i know it can't bee the charging system because if i rev up the motor the volts go up so i know thats workin any ideas???
   / maybey a dead cell in the battery??? #2
Make sure You have GOOD grounds
   / maybey a dead cell in the battery??? #4
Don't sweat the .4, it's most likely you and/or your leads.
What brand DVM ?
the dvm is built into the dash on the rhino nromally i wouldn't be worried about a .4 drop but i had to jump start it before that drop happened now it seems to not wanna go over 14v. just didn't wanna get stuck in the woods i might have to run me a 2 battery system like i did on my hpx it came in handy for these things when a dead battery happend to come along. i let her set all night and i'm gonna try to see what she does in a few hours hopefully she fires up again.
   / maybey a dead cell in the battery??? #6
Typically the charging system will have to work harder to maintain a bad battery. Usually you will see voltage in the 15 volt range. A good battery will only accept so much charge. 13-14.5 volts is about normal. If you have any doubts do a specific gravity or load test on it if possible.
can't it's a sealed battery but it's reading normal again ??i'm gonna start work on a extra battery box as soon as i can just so i can have a spare battery .
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57453)
New/Unused 20ft...
2020 CAT 308 (A53317)
2016 John Deere 35G (A55272)
2016 John Deere...
JCB 3CX 14HFCA BACKHOE (A52709)
JCB 3CX 14HFCA...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
UNUSED SDLANCH SDLGC80 ELECTRIC GOLFCART (A58375)
UNUSED SDLANCH...
