May have gone a little too long before replacing the blades on the brush hog
   / May have gone a little too long before replacing the blades on the brush hog #11
I am not the OP so hopefully he will forgive this intrusion. I am in a similar situation as I bought my first tractor and brush hog about 7 years ago. My blades look like his. But I didn't see why they couldn't be sharpened. So this last weekend I took a Dremel to them. (I don't have a shop where my tractor is and am a little intimidated at trying to undo that large bolt. I guess I would measure the nut, buy the socket and a piece of pipe to extend my breaker bar and have at it but back to the point.). I positioned the tractor and brush hog so I could lay under it, put a jack stand in place in case it came down and went at the blades with the Dremel. It took maybe 15 minutes and I sharpened the blades too much as read the advice. In my naive mind, I don't intend to replace the blades until they shake the brush hog from being out of balance or lose so much metal that they are appreciably shorter.
I would phrase would I did as advice but I am naive in this area. I just have a Dremel and am not afraid to use it.
The only real problem I have with the brush hog is my wife likes running it so much that she gets most of the seat time on the tractor. :). I appreciate her help even if it means I do all the maintenance including changing the shear pin/bolt. I find it amusing that I can be several hundred yards away, hear a bump as she hits something and note that suddenly the brush hog is much quieter. I know she will be over in a few minutes and I get to change the bolt.
Anyway, hope the OP doesn't mind the naive ramble. Thank you to all for advice that I am sharpening the blades too much. (But the cut grass looks nice from sharp blades.)
   / May have gone a little too long before replacing the blades on the brush hog #12
You use the tools that you have. I'd put an angle grinder from Harbor Freight on your wish list. Sometimes it's a small tool to do a big job, other times it's a big tool to do a small job. I once used an excavator with a 30" bucket to lay a 1" water line. It's the only digging tool I had access to and I've done things the other way around. Think about how you get an 1.5" hole in 3/8" steel without a hole saw and only a hand drill. It can be done, it just takes a long time.
   / May have gone a little too long before replacing the blades on the brush hog #13
OP, those don't look bad at all, just a bit of sharpening will do.
When the tips get rounded then it's definitely time.
   / May have gone a little too long before replacing the blades on the brush hog #14
It's easy for me; I sharpen my blades at least once a year; usually twice, and when my mower leaves a little strip uncut down the middle, it's time for new blades.
   / May have gone a little too long before replacing the blades on the brush hog #15
USTMD Those blades are not much worse than the blades on my mower which I do try to sharpen about twice a year. Of course, I mow year around but from the end of April to the end of November I must mow weekly. My cutting area includes Bermuda grass, gravel (pea size) and weeds. I used to mow the top of the irrigation ditch but after they started using weed killer last year I've stopped mowing it. Nice to see others who "forget" to check their blades for wear. At least you have a good tool now to remove nuts & bolts. I have had impact wrenches but recently got a battery powered impact wrench. Wow, what a difference.
   / May have gone a little too long before replacing the blades on the brush hog #16
If I still had a brush hog I would be envious of your blades. They look just like new (ish).
Lots of time left before they need sharpening.
Switched to a flail mower, havn't looked back.
   / May have gone a little too long before replacing the blades on the brush hog #17
<snip>
Then on Saturday morning, I was in Tractor Supply, where I found this on sale:
DeWALT High Torque 1/2 In. Impact Wrench Kit at Tractor Supply Co.
I didn't think twice.
It spun the bolts off no problem--even the one with the stuck cotter pin.
The hardest part was getting the pins to break loose, but more PB Blaster and some pounding eventually did the trick.
Okay--so maybe the blades where worn done a bit. :laughing:
Thanks for mentioning the Dewalt on sale at TSC. I'd been thinking of picking up something & that was enough incentive to pull the trigger. The DCF899 is a good addition to the tool box.
   / May have gone a little too long before replacing the blades on the brush hog #18
I use Y blades on my flail mower, but I still sharpen them too. I can get about (4) sharpening's before the blades are toast.
   / May have gone a little too long before replacing the blades on the brush hog #19
MIKE FROM "ASKMIKE.COM" HAS A COUPLE OF VIDEOS ON SHARPENING BUSH HOG BLADES---WITH A COUPLE OF DIFFERENT OPINIONS.
   / May have gone a little too long before replacing the blades on the brush hog #20
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
17501-FL (A56857)
17501-FL (A56857)
