Maximum Axle Load
/ Maximum Axle Load
Found it. Contrary to YouTube video on front axle loading, some other manufacturers do publish the axle loading numbers. And the Max 22 is significantly higher than the two in the video. Enough that I’d say the ballast requirement is more about safety concerns than axle loading. The picture is from my owners manual.
Believe the major difference between the Max 22/25 And the Max 24 is related to tier 3/4 emissions. My tractor is also 1700 lbs with. FEL capacity of 900 lbs
Thank You!
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
2020 DRAGON ESP...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
207283 (A52708)
207283 (A52708)
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
