Max28XL, Not Turning over when Key is turned to start.
   / Max28XL, Not Turning over when Key is turned to start. #1
Scrambler82
SoCal
Mahindra Max 28XL, HST, TLB
Hello,
I drove my Max, dragged the road with the Grader/Scrapper, all was well.
Took my two buckets of trash to end of the 1/4 mile drive, all was well.
Shut off the Max, let it set overnight.
Went to start the Max the next day and nothing !
Gauges worked, flashes/directionals worked, but headlights didn't work !
I charged the battery, with no affect !
I checked out all the fuses in the Main Panel under the Hood, next to the Firewall, all checked good with the Multimeter, 0 resistance.
I then by-passed the Clutch Safety Switch by connecting the two leads together (was having a problem there anyway), still nothing.
So... here I sit, broken hearted... you know the rest; what do I do next.
Is there another Circuit Panel, Safety Switch, or does the starter have a fuse on the engagement wires ?
PLEASE, if anyone can help, post !
Thanks for reading.
   / Max28XL, Not Turning over when Key is turned to start. #2
Sounds like issue with battery cables. Check the connections to the post and also the ground to the frame. The battery cables can glaze over on the inside preventing good connection to the battery post. Remove and use wire brush or real course sandpaper inside the clamps. Easy to test with jumper cables.
Thx for the reply but I have power at the Dash and with the rear lighting.
So I'm thinking the battery cables should be working ok.
The battery is about six months old with new cables, Connector pads and corrosion paste !
   / Max28XL, Not Turning over when Key is turned to start. #4
I’m not a max guy but I recall their being a bigger hidden fuse or relay that would produce those symptoms. Search for the 26 max and 28 max starting issues to see where it’s at.
When mine did that I had bumped the PTO lever with my jacket. I’ve also heard of seats getting cold enough you had to put your knee into it to trip the seat safety.
Thx for the idea.
I already jumper the seat safety too !
I tried what I knew, now looking for help.
Starting Problems... thx !
   / Max28XL, Not Turning over when Key is turned to start. #6
Look closely at the ground connections. I think the head lights and safety (starter) relay share the same ground.
Thanks, interesting that those two circuits share a ground.
I replaced the battery about six months ago and cleaned up all the connections in the battery area.
I will check it out and let the site know what I have come up with.
Ltr
Thank you all for posting !
I was reading the posting, (link by LouNY), about the Max26 having similar problems, it mentioned about a safety Switch on the PTO Lever. Thx U !
My Max28 got parked and wouldn't start the next day, almost similar !
I ran out to check the Lever and the Switch, luckily my left rear fender had been removed to replace a rear Hydraulic Line and not reinstalled yet, Wham/Bam, it was the Shift Lever it had moved just enough to disengage the safety switch. I must have hit the lever when I got off the Tractor rah other night.
THANK YOU ALL, I was about to hire someone at $110/hr now I'm back to driving the Max.
God I luv this Site, a wealth of knowledge awaits !
p.s. I'm glad it was just a small thing, but now I have to recheck and re-hook up the Safety Switches I disconnected !
I checked my battery terminals and frame and starter connections, all have a lot of dirt on them and it looks like between the connectors, thx.
Going to clean things up and use some more conductive paste.
2014 DOONAN (CHAPARRAL) 502BBNHTTBZF 50FT CONESTOGA XP SPREAD AXLE FLATBED (A52141)
2014 DOONAN...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
John Deere 652R (A50121)
John Deere 652R...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
John Deere 4420 Combine (RUNS) (A50774)
John Deere 4420...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
